Front Rims
BobDebbie
10-09-2005 17:53:19
Hi All, My Dad bought a Allis WD and was in need of a front rim but we have been told that a 5 hole rim is rare and the 6 hole rim is the norm.
My question is which is right? just wondering what is right for the tractor as I have found a rim for the tractor but keep getting told it should be a 6 hole.
Thanks In Advance
Bob
Kip[UT]
10-10-2005 04:41:05
 Re: Front Rims in reply to BobDebbie, 10-09-2005 17:53:19
It's interesting that AC did use a 16" 6 hole by 51/2 pattern disc wheel on WCs starting in late 1936 through 1937 when they first switched from the 17" hub-mount spoke front wheels. By late 1937 the 16" 5 hole by 51/2 pattern became the standard that was used on the last unstyled WCs, all WDs, 45s, and the early D series tractors, before the 6 hole wheels once again became the standard that still exists today.
jk
10-11-2005 15:08:01
 Re: Front Rims in reply to Kip[UT], 10-10-2005 04:41:05
full size ford truck take a 5 1/2 center wheel, from 1980 to i'd say 1996, to be safe. if in a pimch a local junk yard mith have some wheels to get by.
Texas Denny
10-10-2005 09:25:12
Excellent information. Thanks,
acnky
10-09-2005 20:07:41
6 hole is the norm, now. not in the 50's.5hole on 5.5" center for your wd
acnky
10-09-2005 20:06:18
buford
10-09-2005 19:32:59
I have 2 wc, 1 wd, 1wd45, all have 5 bolt wheels cant see how 6 bolt would fit I have just bought a new wheel for wd45 cost 42.00 at local parts store, hope this helps.
Texas Denny
10-09-2005 19:26:45
Unfortunately your expert is wrong! The WD and WD-45 both use a five hole rim. The rim from a WC, WF, D-17, D-14, D-15 will also work for you.
Your expert is way off base. If the hub is a 5 bolt hub (standard), it is impossible to put a 6 hole rim on it unless you restamp the rim and drill and mill 4 or 5 new holes.
If you have a 5 hole Allis rim, you're cool. However, all five hole rims are not the same. I don't know what other tractors or cars use the same bolt center diameter. Safest way is to get one from a WD, WD-45 ... Allis Chalmers tractor.
old
10-09-2005 19:22:35
I think the rims I have from a WD are 5 bolt but with out going out and looking I'm not for sure on that. I have a pair of rims from a WD I'd sell and they have good tires on them to boot
BCnT
10-09-2005 19:18:52
my series 1 d17 has 5 hole front wheels...not sure if it came that way or not but at one time it needed a front wheel and a ford 1/2 ton pickup wheel was it...i drove it about 30 mioes bringing it home so evidently it works ok.
