WD45 Thermostat
Tony Z
10-08-2005 19:33:57
Helo Everyone,
I have a WD45. I put an after market temp gauge on it and the temp never gets above 130. I looked in my service manual and do not see anything about a thermostat on the gas models, only the diesel models. Does the gas have a thermostat,and if so, how do you change it. Thanks for any help.
Tony Z
Bill in IN
10-12-2005 13:05:55
 Re: WD45 Thermostat in reply to Tony Z, 10-08-2005 19:33:57
You might want to consider where the temperature gauge is reading from before you change the thermostat. The original units were read from the radiator not the block so 130 degrees may be reflecting a 160-180 degree thermostat working well.
Tony Z
10-12-2005 14:10:13
 Re: WD45 Thermostat in reply to Bill in IN, 10-12-2005 13:05:55
Thanks for replying. The after market thermostat plugged into the same hole as the factory one, so I am assuming everything is the same as factory.
Jr64
10-09-2005 05:12:59
The thermostat houseing is located right before the upper radiator hose.
Tony Z
10-10-2005 05:40:11
 Re: WD45 Thermostat in reply to Jr64, 10-09-2005 05:12:59
Thank you very much.
