Roto-Baler information wanted
Jeff Oliver
10-08-2005 18:16:31
We just acquired a Roto-baler and are wanting to get it going again. Not to use alot but to play with. it is in really good condition and looks to need only a few springs and someone who knows how to use it. :)
I have heard that you use binder wine in hem but have no clue exactly what that is. I know baler twine but the bundles won't fit in the holder, where do I get that? Also, how does it either stop rolling when it gets the bale to size or let you know, I can' find a indicator on it.
What experiences has anyone had with them , good or bad? I am interested in hearing them and those balers have always fasinated me.
Jeff Oliver
10-09-2005 19:52:16
 Re: Roto-Baler information wanted in reply to Jeff Oliver, 10-08-2005 18:16:31
I appreciate all of the information and stories. Sounds like it will be fun ot run once everything is going right. I am going to order all three manuals for it sometime this week. I doubt we will get to try it this year but come spring... Heck if I can find some straw to bale I might make some "cute " little round bales to sell.. LOL!!!!
DP
10-09-2005 19:02:45
Grew up running them. The advice given below is correct. I only want to add, be sure you loosen the brake before you start baling, and don't be afraid to put too much oil on everything! Carry a can with you. It is my theory that if it could be backed in an oil pit, thats how to start the season! LOL Above all, think before you act! Its machinery, and will have no mercy if it gets ahold of you. Don
Doug in OR
10-09-2005 18:20:52
I hope none of your missing springs have adjustment screws on them. These adjustments can be difficult to set right. Do not cuss the baler if the adjustments are not correct. Use a little patience and it will do fine.
Roger A. NY
10-09-2005 06:39:30
The baler stops feeding by its self when the bale gets big enough and the twine tube will drop when the last of the hay enters the chamber thus pulling the twine in to start wrapping the bale. Binder twine can usually be found at farm stores and if not in stock can be ordered. If that fails check at an Amish settlement if you have one near by.
As far as being EATEN by one that can happen only if you are IGNORANT enough to service, lubricate or adjust the machine while it is running just like corn pickers, choppers or ANY other piece of equipment. My Dad bought his first AC roto baler in 1948 and used them for about 30 years and was never eaten by one or close to it. He baled hundreds of thousands of these bales as some years we put up about 30,000 bales of hay and nearly 15,000 bales of wheat and oat straw for us plus did some custom work around the neighborhood.
As far as plugging we had very little problem with that. You definetly have to learn how to rake hay properly for the baler! It is best if you rake windrows together side by side so the table is full all the way across to make the bale even. If raked properly it will really eat hay! In some conditons my Dad would do 10 bales a minute. He also baled for many years with a 1943 Farmall H which of course did not have live p.t.o. Many people told him that it would take the clutch out but he never had to put a clutch in that tractor in all the years he had it. In about 1954 he bought a Farmall M and put a M&W live power clutch on it and used that to bale with but kept the H for many more years. Later he used a WD45 AC and a D17 folowed by a MM Jet Star.
If you could find someone in your area with experience with one his info and directions could by very helpful. They are a little different from other balers but once you learn how to use them they can be a nice unit. One big thing I remember was my Dad said to make sure the latch plates were not worn as they would cause a lot of problems. Also if some one has replaced the belts, they have to be even and not heavy duty belts as the will not roll the bale correctly and cause all sorts of problems. The belts have to be very flexible to work well and make nice smooth tight bales. Some people will tell you that you have to put on the endless belts but it is a big project to do so, so my Dad put on spliced belts and had very good luck, but he had a lot of experience.
Sorry this is so long but I hope I have helped some. Oh the best help I can give you is to get an OPERATORS MANUAL. they can be found on ebay and I think an AGCO dealer can get one for you if he is worth his salt! Roger
Doug in IL
10-09-2005 05:58:49
I had one I used for several years a long time ago. As I remember, when the twine tube drops down to wrap the twine, the hay conveyor stops running. You have to quickly stop the forward travel of the tractor while leaving the PTO running. (a tractor with a independent live pto is VERY helpful) The bale is then wrapped with twine and ejected from the baler. The hay conveyor will then start runnig again and you resume forward travel with the tractor. I also remember that keeping the knife that cuts the twine very sharp is imperative. At that time, I never had any trouble finding twine for it, as most all of the farm stores carried it. I think the binder twine balls were even marked as suitable for RotoBaler twine. You might check with your local farm stores. They may not carry it in stock anymore, but can probably order it from their suppliers. Might check with your Agco dealer. I'm sure they can get it also. If you keep it lubricated, have a decent set of belts on it, keep that twine knife sharp, and get some experience using it, it will bale fine. You might try to find an operators manual for it. Sometimes they are on ebay. Your Agco dealer can probably order a manual too. I always kinda enjoyed using mine. They are not real fast, but will bale your hay.
Roger A. NY
10-09-2005 06:57:22
 Re: Roto-Baler information wanted in reply to Doug in IL, 10-09-2005 05:58:49
Doug in IL, Sorry to say many of the same things you did, must have been typing at the same time, it is just that you must type faster than me---- in fact most everyone types faster than me! Roger
Doug in IL
10-10-2005 07:13:39
 Re: Roto-Baler information wanted in reply to Roger A. NY, 10-09-2005 06:57:22
I don't know Ron, I am pretty much a one finger typist! If I get on a roll, on a good day, maybe 2 fingers! Your post, and the others, did bring back a little more memory. Especially making sure the brake is working right and the latches being good. And I do recall getting off the tractor to toss in a wisp of hay to get the twine started. It's kind of amazing sometimes that people have the very same experiences with some of this old machinery, no matter where in this big country we live.
Doug in IL
10-10-2005 07:15:59
 Re: Roto-Baler information wanted in reply to Doug in IL, 10-10-2005 07:13:39
Roger, I meant Roger, not Ron! Too early yet, I guess!
old
10-08-2005 21:38:04
You could give me one of those, had one years ago and sold it after the first season I used it. They clog easy and will eat you if not careful with it.
JMS/MN
10-09-2005 17:17:27
 Re: Roto-Baler information wanted in reply to old, 10-08-2005 21:38:04
Dad bought his in'48, used it through '64. Baled thousands each year, never replaced a belt, had one piece welded 2-3 times- the catch (cast iron piece), that controlled the release mechanism. Only repair all those years. Need to make double windrows to get a decent bale. He never clogged it. Most years ran it with the WC, no live pto- much easier after he got the WD45 in '56. Only time he got off the tractor with the pto running was to toss a bit of hay into the rolls when the twine did not catch, after the arm dropped down, and there was a rope to pull to reactivate the feed conveyor to pull a bit more hay into the machine to catch the twine- but that would require moving the tractor forward to get back into the windrow. There is no need to get stuck into the machine. Taught my six kids the same way - and they all left home with all digits intact. Some people did not like stacking round bales, but they shed water better than the little squares. In those days we had little inside storage, and the rotobales would weather better than any others.
