cracks
Corn Cobb
10-08-2005 14:38:32
Just pulled the engine out of the wc, pull the head off and found cracks between the sleeves, but not on the outside. Should this block be junked or can alumseal be use once it's put back together? Thie engine was stuck so I pounded the sleeves out from the bottom,broke one piston and it was aluminum is this factory.
Thanks Cobb
chalmersbob
10-08-2005 18:54:12
 Re: cracks in reply to Corn Cobb, 10-08-2005 14:38:32
cracks are not a problem. head gasket seals the area of the crack. most blocks are cracked there.
stock pistons were cast not alum. engine must have been rebuilt. BOB
