Newbie D 15 Questions
John T
10-07-2005 14:52:25
I never owned one in my life but just bought a D 15 at auction with a Kelly 400 loader and dont have it home yet, but have some questions based on only a little time to check it out so far.
1) Does that High/Low shift lever on the right have any dead mid point where the PTO continues to turn but the tractor dont move like on the WD 45????? ???? (I called that Fake Live Power lol)
2) Its bad to wanna jump out of 3rd gear under a load, is fixing that gonna require the tractor be split front n back or side to side or can it be repaired by removing that big side tranny cover plate on the right side????? ?
3) Will it need a new gear or what (makes a rolling sound), and can it be changed via that side plate removal or she gotta be split and where???
4) Will it make things even worse if I were to use a bungie cord to hold it in 3rd gear????
5) The loader lifts AFTER the valve to it is opened and the 3 pt rises to the top. If one wants to use that rear pioneer hydraulic coupler, does some other selector valve have to be switched over to power it instead of the 3 pt lifting????? ???
6) I take it that gas gauge that mounts in the tank is strictly a mechanical unit and needs a new float or something, it stays on empty?????
7) Any after market places to buy a new good replacement seat without having to go to a dealer????
8) I never understood what all that traction control lever does, whats it do and where should it be kept if using the 3 point hitch???
9) I HOPE it will lift a big round hay bale both front n back without tipping up or down??? But it appears one would have to lift a bale on the rear first then open the loader valve and load another bale on the front???? Im not sure thats even gonna be possible (2 at once) any thoughts????? ?????
Sorry so many questions, thanks in advance.
John T, electrical engineer and a JD man, new to the Allis world
Texas Denny
10-08-2005 06:36:50
 Re: Newbie D 15 Questions in reply to John T, 10-07-2005 14:52:25
John, I'm sorry that your post has gone awry and taken some convoluted turns. A person should be able to come here and ask opinions and for help without a lot of extraneous arguments to confuse the issues. This happens occasionally when competitive brand names are mentioned on these boards. Such behavior is not limited to John Deere owners. It is frequently seen in Chevrolet, Ford, Allis, Massey. . . It stems from deep insecurity that their brand is not held in the same regard by every person that it is by them.
I have lots of tractors and like them all. With 8 different brands, I like to turn them over so I can experience different brands and models. Some are better at certain jobs than others. Some I like so much, I'll never be able to sell them. Others, I've enjoyed and am willing to sell to make room for something different. I have a D-14 which is very similar to your tractor. I use it a lot. I'm sure you'll find it capable.
Another post made me think. Round bales are very heavy. I don't know if the front end or the loader of this tractor will stand up to lifting bales. Steering might be strained. If the loader can stand the load, loading the rear first would relieve some of the strain on the front end. You need the three way for that. The three way must be closed port when not selected. It is an interesting, relatively low cost experiment. Come back and give us updates on what you learn.
The front mounted pump is good but expensive. Until you know the tractor can handle your job, it would be cheaper to use the valve solution and prove it out.
Good luck.
John T
10-08-2005 09:26:57
 Re: Newbie D 15 Questions in reply to Texas Denny, 10-08-2005 06:36:50
Thanks Denny, Yep my post sort of got hijacked. I provide a lot of electrical help to others n was looking for a lil newbie mechanical help here I didnt wanna start any fights lol.
I have ordered BOTH the IT and an AC D 15 maunual so that will help. I had a Cockshutt 30 and its not any bigger then the D 15 and it handled 2 big bales, but IM NOT gonna overload or overwork this D 15. Im confident the heavy 3 point that was added to the rear can handle a rear bale at least (I may have to toss a couple wheel weights in the loader for ballast) so the front I will just experiment with. I dont have far to carry the bales and its level n smooth to my hay lot.
One last question if we dont get hijacked and before my manuals arrive, Just where is the tie in plumbing/connection point where I could plumb in a 3 way, 1 in 2 out with closed center???? It has a line on the right front where the gate valve is now to energize the loader, but I would need to T up so I can choose EITHER the loader or rock shafts and I dont remember seeing any obvious places to do that????? ?? That sort of ties in with my earlier question of how does one energize that single rear pioneer hydraulic coupler outlet????? ?
Thanks again, John T
Texas Denny
10-08-2005 12:26:19
 Re: Newbie D 15 Questions in reply to John T, 10-08-2005 09:26:57
I've got the AC-6 manual which is strictly for a D-14. I believe the D-14 and D-15 are exactly the same. You probably got the valve connected to a port on the lift valve. Another port will connect to the steel line that goes back to the "pioneer hydraulic coupler". These ports are plumbed together if it is like the WD valve. Never worked on my 14 so I'm not sure what you have.
That coupler you refer had a couple of designs. One design held back pressure untile the lift arms were up and than the fluid went to a remote hydrailic cylinder for lifting the tail wheel on a semi mounted plow. The other design had pressure there at all times for lifting disks and other trailing implements. You need your three way valve to interupt the flow to the lift cylinder. Is your lift cylinder exposed or is inside the the differential case? It was always inside the case on a D-14 and every D-15 that I've seen. But a Series IV D-17 has external cylinders. I don't think the Series II D-15 had external cylinders.
Try to find where the steel line is connected. It may be a flare fitting rather than pipe thread. Post back when you've figured out how the steel line is connected.
I just checked IT manual AC-17 which covers the D-14, D-15 and D-17. It says there are two types of valves mounted on the differential case. One is called a selector valve and the other is called a transport valve. Their function is pretty much as I described above.
Click on my name at the top of this post and send me an email. I'll send you back the script describing these valves.
You could put the three way ahead of the selector or transport valve behind your seat on the left. You would be able to reach it from the seat and switch back and forth. It will be a piping challenge because I think they are all flare fittings into these valves.
John T
10-08-2005 16:01:15
 Re: Newbie D 15 Questions in reply to Texas Denny, 10-08-2005 12:26:19
Denny, I sent an e mail and this is about the same report. I just tried the rear 3 pt hitch, its a regular AC 3 pt adapter a good n heavy one that mounts up underneath into the regular AC bottom coupler. IT PICKED UP A 1500 LB BAIL LIKE IT WAS NOTHING and it didnt sway or drop, handles it like a charm.
Okay on the hydraulics. All it has is a single outlet on the top right hydraulics body near the valve which the dash lever controls, with a single line out that goes over on the other side to a brass looking TEE and one line out has a jury rigged gate valve to shut the loader on or off while the other factory looking original line goes back to the Pioneer Coupler outlet. THERES NUTTIN ELSE ANYWHERE. Theres no lines or fittings or manifolds I see where I could divert flow from the internal rock shaft cylinder (now 3 point lift) to the loader.
Sooooo o Im thinkin its not all that bad as it is maybe if I add a better loader shut off valve that levers instead of screwing in or out it will be easy to lift a bale on front,,,,, ,,then close the valve so it dont drop,,,,, ,,,,then lift my rear bale,,,,, ,,when I get to my hay storage lot I open the loader valve to lower the front bale then push it into my stack,,,,, ,then turn around and place my rear bale on the 3 point.
The only way I see to improve things is to add one of those front crank pulley driven Hydraulic Pumps and re valve everything for independant and live hydraulics. YOU GOT A LINE ON ANY USED FRONT PUMPS????? ??? Thats another project maybe next summer if I keep the tractor. Im confident the front will also handle a bail. The loader cylinders are good and the lines and it snapped it right up on the rear so the hydrailic capacity n pressure must not be too bad. The front of the tractor is good n soild with good tires I carry about 75 lb of air in so I think it will be okay, if not, I wont use it.
My IT and AC Manuals should be here next week so I can change all my fluids. She runs like a watch.
Thanks, John T
COWMAN GA
10-08-2005 03:11:01
Concerning moving two big bales of hay at the same time I think the D 15 is a little small.According to Terry Dean's book on A-C's the D-15 weighed in at about 4000lbs. A bale of hay weighs average 1000lbs. Two of them might be a little much with my experience.This tractor is 40+ yrs.old. That much weight on the front spindles could be a problem in the future. Remember,when this tractor was designed,big bales of hay were'nt around to practice on.Could be kinda dangerous,it don't hurt to be safe.I'm not saying that A-C'are'nt tough,they are.Around here,the A-C's always kick at the pulls.I'm just saying you'll be money ahead to match the tractor to the job.I run 3or4 different makes of farm tractors and believe it or not,they all break down from time to time!!
JMS/MN
10-07-2005 15:35:32
The midposition on the Power Director gives you live hyd and pto. Live is live, not 'fake' or any other name. If you can stop wheel motion, without stopping pto, you have live power. Doesn't matter what the system is to get to that point. If you can engage pto/hyd without stopping wheel motion, then it is independent. The factory hitch system is not a 3ph- it is a Snap-Coupler with two lift arms. The arms can be locked up if the tractor has a transport valve mounted on the rear end. Usually the arms stay up during loader use after they raise the first time. If not, you can simply use a light chain to hold them up, sans a transport valve. Third gear repairs require a tractor split. If people had not ground the gears all these years, instead of waiting for the clutch to do its function, third gear would not be an issue. The fuel guage likely has a cork float on it- wire inside the tank. Traction control lever works on mounted implements- called Traction Booster. Basically sense when you are getting stuck with a mounted implement, slightly raises the implement to add weight to the rear wheels, pulls you through- just like modern weight transfer system on other tractors. WD/WD45 control was on the lift lever- was reset each time with a slight raise of the lever upon lowering the implement. D Series came with a second lever to set it once in the field. Relative weight transfer is indicated by the guage- if you set the lever too high it raises the implement, losing depth control. If you are using a bale fork, etc., rather than a tillage implement- leave it at the bottom of the quadrant. You cannot use the loader and the Snap-Coupler lift at the same time. You can put a separate pump on the tractor to control the loader. Check the front crank pulley- likely tapped with four holes for the front mount pump.
John T
10-07-2005 16:02:11
 Re: Newbie D 15 Questions in reply to JMS/MN, 10-07-2005 15:35:32
Thanks to you also, Im learning here fer sure. I guess Im gonna get it home n mount my rear bale carrier and lift a bale and then see if it stays when I open the gate valve that allows the front loader to work????? ?? It simply has a gate valve to the loader line now and the rear lift always goes up, so maybe if its open I can lift a bale on the back then the loader will lift another?????
I really like the idea of a front mount pump. That way I could use it for the loader only. You have any sources for a new or used unit that will couple right up to my front pulley if I have the right one????? ????
Thanks a bunch
John T
JMS/MN
10-08-2005 08:12:59
 Re: Newbie D 15 Questions in reply to John T, 10-07-2005 16:02:11
The front pump mounts in front of the steering casting, with a shaft going through the crank hole, back to a bracket bolted on the pulley. Could use any style pump, have a coupler fabbed that matches the tapped holes pattern. Can check with salvage yards for parts too. Your idea about the gate valve- don't think it'll work- when you open the valve in the loader line, drop the loader, then the rear arms will go down too. Maybe not if you have a transport valve back there.
Texas Denny
10-07-2005 15:32:05
1) There is generally a little creap when in the center position if you don't have an implement. My D-14 moves when there isn't a load. But when the baler is on it, it stops and stays stopped.
2) The wanna jump out of third is not easy to fix. Many have solved the problem with a different set of forks (behind that side plate you mention). It is possible that it could need forks and two gears - worst case. Replacing gears requires splitting the tractor. Replacing the forks will not require splitting. It might be a task finding good forks. I think the forks can be rebuilt but requires a mill, special cutters and a lot of skill. The one time I had this problem, I found a better set of forks, installed them and solved the problem. Forks may not solve the problem if the gears are worn out.
3) see #2
4) Using a bugee cord will hasten wear on the forks. Eventially, the wear will get so bad that it won't move at all in that gear.
5) Sounds like you have the standard hydraulic system. The lift arms and loader cylinder are on the same output so the lift arms will rise first and then the loader. With this setup, you won't be able to lift with the front and the rear at the same time. You could add a three way valve to select either the loader or the lift arms. With this valve you could lift both front and rear independently (but still not simultaneously - first one then the other). You could tie the lift arms up so you don't have to wait for them.
6) The gauge is mechanical and has a cork float on the end. I used a wine cork on mine and it works fine.
7) You may be able to pick up a seat on Ebay. Used one are common. New ones are available for a lot of tractors for $40 to $60.
8) The traction control works best with Allis Chalmers mounted implements. It transfers the weight of the implement to the rear wheels of the tractor to improve traction.
9) I think I covered that question in #5.
Good luck. A D-15 is a very handy tractor. You'd need a 1010 or 2010 to compare favorably.
Denny
Newman
10-07-2005 19:22:27
 Re: Newbie D 15 Questions in reply to Texas Denny, 10-07-2005 15:32:05
Hey Texasdummy, people with past experience don't really need a wise crack like comparing a d-15 with a 1010 or 1020. deere had good hydraulics and drive train and engine. a-c had poor hydraulics,sorry transmission and the engine was ok. so txdum ,who's still in business,a-c or jd.
Hurst
10-07-2005 20:09:22
 Re: Newbie D 15 Questions in reply to Newman, 10-07-2005 19:22:27
Wow, opinions, opinions, opinions. Before you go around saying allis built a sorry tractor, maybe you should think about the times. When it was built, there was not a standard for a hitch, and to be honest, deer was one of the few that didn't have their own design. Ask anyone that used a 3pt and a snap coupler and they will say that the snap coupler was a better system than the 3pt. It could put the weight where you needed it more effectively than most anything else out there. The hydraulics were high pressure on the early d15s with a low volume. This is just what allis built their equipment to use, so yes, they may seem poor to todays standards since the cylinders are about 2 times the volume of what the system was designed to operate. The drive train problems were user related, even the 190xt. If the tractor was left at the rated HP, they would hold up just fine. The popping out of gear is caused by people grinding them into gear instead of waiting for the clutch to do its job. Being is business still does not mean the company made a better tractor. And if you want to be critical, AGCO stands for the "Allis-Gleaner" company, so Allis is still around, just like deere, even if the management has changed hands. I am sure that you were there keeping the books to know why allis shut its doors??? It wasn't because they made a bad product, it was their reliance in construction equipment, which JD didn't have. JD just got lucky in what they chose to build at the time, thats about it. I don't see where you think deere had everything so much better than Allis. Allis also had a lot of firsts in the market that are still used today, something deere can't say, so yes, they did make some mistakes, but you can't expect everything to be perfect the first time either. Deere had its mistakes too. I wouldn't call the 4010 and 4020 series motors flawless either, would you??? From what I heard, they had some problems too. Before you go bashing, get a view of both sides. The guy asked a simple question. If deere was flawless, then the forum should be empty, but guess what buddy, they aint empty. If you don't have anything to say that will help, then SHUT UP!!!
Hurst
Hurst
10-07-2005 20:11:10
 Re: Newbie D 15 Questions in reply to Hurst, 10-07-2005 20:09:22
I forgot to add, he is accurate in the comparison. The d15 was a 3-16 plow tractor. The D17 was a 4-16 plow tractor, so that shows that the comparison was pretty close, because if I recall, the 2010 is a 3 bottom tractor too?
Hurst
mace 56
10-07-2005 20:41:16
 Re: Newbie D 15 Questions in reply to Hurst, 10-07-2005 20:11:10
Deere no doubt found a good recipe with the 10 and 20 series. Before that the 2 cylinder tractor designs were getting pretty dated.
A bit later as the markets were shrinking their management avoided some bad decisions and they withstood some hard times that killed off a lot of the other companies.
None of this has anything to do with playing around with old iron just for the heck of it or restoring something that brings back a few fond memories of days before you bought new tractors with funny Chinese characters on all the data plates.
Newman
10-07-2005 20:40:47
Way back then you could buy a new a-c much cheaper than the name brand stuff back then. Thats why people bought them and you can't really blame them ,cause they were trying to save money. People that bought the a-c stuff back then were real farmers. Most of the people that buy them now are just hobby farmers and folks that need something to do. Correct me if I'm wrong. Oh by the way,you can shut your trap too.
Hurst
10-08-2005 06:48:28
 Re: Newbie D 15 Questions in reply to Newman, 10-07-2005 20:40:47
I know for a fact that you are wrong. I just bought a 7000 and it works the same, if not more than our fords on our farm. Where do all of those 2 cylinder jds go??? I don't see many of them out in the fields. We used our D17 series 4 all the time up until we sold it because we needed something with a 3pt hitch instead of snap coupler, which we bought it with new because we had all allis impliments. My uncle still uses his 180 diesel a lot to haul manuar. A few people down the road still use their allis tractors, none of them have had a restoration either, maybe an engine overhaul, but that is because they were used about 10,000-12,000 hours before, and I know this because that was the case with our D17 diesel. Allis tractors were not "cheaper", they were fair priced. Look at the profit margins for allis compared to deere. You will see that Allis relied on selling a lot of tractors instead of high profit margins. I also don't know what you mean by cheaper than the brand name stuff. Allis was the brand name stuff. On our farm, since we used tractors, it was all allis. I know my grandfather and I know that he bought allis tractors for a reason, because they would last. Also, allis tractors were much more advance than JDs at the time in design and options. Look at all the firsts allis had, more than any other tractor maker in those years. I'm just curious, but where do you get all this information??? Sounds like your just on this board to pi$$ people off. Why don't you just walk over to that little old JD board and leave us alone. If you don't want to answer people's questions on this board, then get the he!! off, I am sure others are tired of you too, not just me!
Hurst
Newman
10-07-2005 20:28:55
Hurst the issue here is not the power but the reliability or something like that. We are on the subject of hydraulics and power trains. And for pulling bottom plows,it depends on what type of ground you're on.
Hurst
10-07-2005 20:40:26
 Re: Newbie D 15 Questions in reply to Newman, 10-07-2005 20:28:55
By plow ratings, that is what the manufacturers rated them in ideal conditions, which are not always what you have. I know on our farm, our ford 7610 is maxed out at about 4-16. In reliability of the powertrain and hydraulics, I would say that the D15 was one of the best for its age. You have to remember these tractors were around before there were computers to machine everything to near perfection, so tolerances were not as tight and therefore, a lot of parts would probably wear a little faster than tractors of today. My point is that the D15 was a wonderful tractor, and there is no reason to bash its brains out. Deere had some wonderful tractors too, just like every other brand and they all had some screwups too. I hope this is a little easier to understand.
Hurst
Sid
10-07-2005 19:58:14
Newman I sure am glad most John Deere owners act a lot more mature than you do in your reply.
Newman
10-07-2005 20:19:25
 Re: Newbie D 15 Questions in reply to Sid , 10-07-2005 19:58:14
Sid, I really appreciate that you see my point of view. It takes someone that is beyond maturity to educate people about what to watch out for when buying a used tractor. I was born and raised on one,and from my past experience with new and used taught me to stay away from them. Sorry about that. My opinion,free country.
Texas Denny
10-07-2005 19:42:24
Anyone is entitled to an opinion no matter how prejudiced he is or how rude he may be. I don't believe this board should be used for name calling.
Newman
10-07-2005 19:50:52
 Re: Newbie D 15 Questions in reply to Texas Denny, 10-07-2005 19:42:24
Name calling only goes so far when a person down grades a product to up grade another.
Texas Denny
10-08-2005 06:15:04
 Re: Newbie D 15 Questions in reply to Newman, 10-07-2005 19:50:52
In addition to opinions, you need a refresher in English grammar and vocabulary. The words "favorable comparison" does not imply that one is better than another. It simply means that they can be compared reasonably - with fairness.
Prejudice is a heavy load. Those that have this load carry feelings that are unhealthy and often inaccurate. I have 8 different makes of tractors at the present time. One of them is John Deere. I like John Deere tractors. I like Allis Chalmers tractors. I like Oliver tractors. Having owned and used all makes, I can see advantages and disadvantages to all makes.
If you were looking for advice, to whom would you go? A person who is fanatical about a single brand will not have a broad enough knowledge base to adequately discuss many issues. Being so narrow and having a quick temper will in effect do "his brand" a great dis-service. Such prejudice discredits the brand. Rudeness may cause the newcomers to steer away from the brand subconsciencely expecting that their personalities might be degraded in a similar way by ownership.
And lastly, rude statements and name calling significantly destroy the speakers credibility.
"Favorable comparison" does not judge one item over another. It simply says they can be compared reasonably because their characteristics are sufficiently similar. I was not thinking about hydraulics or which business has had an uninterupted history. I'd used "handy" in the first sentence of the paragraph. Sorry, more English lessons. Since it was in the first sentence, it is expected that the balance of the paragraph would have something to do with "handy". I believe the front entry, easy on/off of the two is quite similar. I believe the controls are all "handy". I believe both have comfortable seats and the steering wheels are in comfortable positions. The foot pedals are in good positions and easy to use.
When you degrade a 1960 tractor because of something that happened 20 years later, is there any fairness involved? How does the corporate life of a company have anything to do with a single tractor and how "handy" it is? Why would you lose your temper because John Deere was mentioned in a paragraph with Allis Chalmers?
Newman, try to relax. I wasn't looking for a fight or trying to hurt anyone. I was just suggesting that Newbie would enjoy his new acquisition. I was sugesting that he would find it "handy" like a 1010 or 2010. I doubt that you would ever discover the D-15 to be "handy" but a man with an open mind like Newbie will probably be able to recognize strengths and weaknesses and fairly consider them.
John T
10-07-2005 15:53:54
Wow, Thanks for the good n quick reply Denny.
1) It feels like a fork problem to me (the jumping out of 3rd gear). Its like the gear shift lever isnt pushing 3rd gear far enough into mesh or like its just barely catching the teeth so under a load she drops out. As compared to the other gears, the shift lever just dont move very far and its like you wish it would move further to fully engage the gears. That sound like a worn gear or a fork problem to you now????? ?? I reckon I will have to pull the side plate and see what forks move what gear when I shift into 3rd and figure her out Eh????
2) The hydraulic line to the loader simply has a gate type shut off valve now. I was wondering if I could first have it closed and then lift a bale on the 3 pt to the height I want it, then if I reach down n open the valve so the loader works, I guess the rear bale would lift ALLLLL LL THE WAYYYYY UP before the loader could lift another one..... ..... ..... ..... Orrrrr rr just leave it in open and back the rear under a bale and lift it to max and then pull the front up to a bale n pick it up????? ? To use a 3 way valve as you mentioned (1 in 2 out) I guess I would have to valve ahead of either (3 pt and loader) and then select whichever one I wanted to energize. I guess if I get it home tomorrow I will just try it n see what is possible as is lol ANY FURTHER THOUGHTS????
Thanks again, this is great. I often provide electrical help to otheres but I need some mechanical help now with a tractor I just got.
John T
Texas Denny
10-07-2005 18:36:06
 Re: Newbie D 15 Questions in reply to John T, 10-07-2005 15:53:54
1) Better forks might give you back third gear. In addition to the fork wearing, it might be bent. The channel on the slider (fork goes over this slider) may be worn. And most probably, the fork from the factory didn't push the slider completely into gear. The first step in figuring it out is pulling the side plate off. If you have a good caliper or a micrometer, measure everything. Examine the knobs on the gears. I have an exploded view of a D-14 which might help you. Send me an email. Compare all the measurements which will tell where the maximum slop is. If the knoba on thord look as good as those on other gears, a fork rebuild may do it.
2) With a gate valve, you should be able to lift with the front loader. Then close the gate valve with the bale lifted. That should hold the loader up. Then the dash controls should raise and lower the lift arms. A three way valve would make them independent. The way you have it, control of the loader will only occur after the lift arms are up. I believe your analysis of the three way is correct. One input port and two output (one for fift arms and one for the loader).
I'm a mechanical engineer who spent most of his career designing electrical control circuits, drive systems and computer interconnect systems. Did a fair amount of machine design as well - gear systems and automatic equiment. Retired now.
Denny
