B and C specifications
Jim Mitteer
10-07-2005 03:08:44
Can someone briefly tell me the difference between the engine and transmissions on these tractors? Are the engines interchangeable?
Thanks.
JIM
Dick L
10-07-2005 03:20:49
 Re: B and C specifications in reply to Jim Mitteer, 10-07-2005 03:08:44
The B started out with a 3 1/4" piston with the C with a 3 3/8" piston. Transmissions were the same.
You wont find many B"s around any more with the 3 1//4" pistons as the blocks were no different and every other engine part was interchangable.
The C final drives were wider than the B"s but they are interchangeable as well. The CA had a fourth speed but you can interchange that transmission with a B or C. They fiddled with the RPM"s as years went by but you can do that to any of them with different springs and a little tweeking if you have an understanding of how every thing work.
Jerry Coulter
10-07-2005 10:52:16
 Re: B and C specifications in reply to Dick L, 10-07-2005 03:20:49
And the tractors have different final drive ratios which gives the B faster ground speed and the C more pulling power.
Jim Mitteer
10-07-2005 11:22:24
 Re: B and C specifications in reply to Jerry Coulter, 10-07-2005 10:52:16
Thanks for your help. JIM
