WD Oil Leakage from Hyd to Trans
Jim B
10-06-2005 17:52:27
Can anybody tell me what is wrong when Hydrulic oil leaks into the Trans case? Certainly the problem must be some sort of seal but I have no service manual for reference. Could power steering "leak-fixer" additive be used?
wdtom
10-06-2005 18:07:42
 Re: WD Oil Leakage from Hyd to Trans in reply to Jim B, 10-06-2005 17:52:27
There is a seal, newer tractors have two, between the trans and hyd. system. The level of hydraulic oil is normally higher and it is thinner so it will tend to leak into the transmission. As I said, older tractors have one seal, newer have two, one facing each way. You can get a kit to update an older tractor. I bought one, $ 60 or 80 if I remember and it didn't have something, can't remember what. I got by because I had some newer parts. The seal area in a newer hydraulic/clutch housing is longer in a newer casting and the seal surface is longer on a newer shaft, so you can install two seals, rear one with the seal lip to the trans, front one with the seal lip to the hydarulic system. I can get you parts nos. and serial nos. of the change over if you like. It isn't too difficult to do the job if you are mechanical. You need to support the front of the tractor and roll the rear half back on a dolly and the rear tires, do the work and reconnect it. Using a maybe 8" long alingment pin screwed into the rear end to guide the frame rails helps a lot. And you need to pay good attention to the shaft alingment going into the clutch housing so as to not dammage the seal you just put in. I would recomend a reprint of a WD or 45 repair manual if you are going to do the job. My AGCO dealer got the seal kit for me in a week or so.
