Valve guides loose?
Bob in Wi
10-05-2005 17:11:45
I picked up my D-17 head from the shop. He showed me that 7 of the new guides just fall right threw, no interference fit. What can I do to fix the head?
DOn Dittmar
10-06-2005 08:27:54
 Re: Valve guides loose? in reply to Bob in Wi, 10-05-2005 17:11:45
Knurling is done to the guide so the valve will fit tight. In the case he is talking, he would have to knurl the head so the guid would fit tight, and i dont think that is done, but I could be wrong. I would check on oversized guides, perfect circle should make some.You should be bale to mic the inside of the head and then the valve, and find a guide to match
BCnT
10-06-2005 10:30:36
 Re: Valve guides loose? in reply to DOn Dittmar, 10-06-2005 08:27:54
no,i meant knurl OD of guide but the more i think about it...oversize would be better...i dont think knurled guide would hold up in a diesel.
BCnT
10-05-2005 19:31:57
dont they make oversize guides? surprised your machinist didnt suggest them...not sure if you got gas or diesel but i've had good luck knurling valve guides in gas engines when fit was loose
