WD transmission
DeLo
10-05-2005 15:07:19
My transmisson will shift fine into 1st and 2nd, but wont hardly go into 3rd and 4th. I know nothing about transmissions. What could be the cause of this and what neds to be done to fix it?
Is it a problem with the trans. or the shifter?
wdtom
10-05-2005 18:21:11
 Re: WD transmission in reply to DeLo, 10-05-2005 15:07:19
The problem is in the cover to the transmission that has the shifting mechinism in it. Or the 3-4 gear isn't sliding easily on it's shaft. Take the cover off and see which it is. If the gear slides ok, check the 3-4 shift fork for freedom of movement. Due to an interlock only one shift fork can move at a time so if the 1-2 fork is anywhere but neutral you will not be able to move the 3-4. Have all shift forks in the middle of their travel--slots for shift lever in line, and see why the 3-4 isn't moving as it should. If you take it apart watch out for the interlock plungers and spring that go between the rails where you can't see them. When you take out a rail the plunger can come out and disapear on you. Likely there is rust or dirt somewhere.
