D17 Rear Main Seal
gh in oh
10-05-2005 09:17:39
Hello all,
My D17 is leaking oil pretty badly from the rear main seal. I was just wondering if anybody had any advice on replacing one. DO i have to split the tractor or can i get to it by droping the oil pan? It is a series one and has the gas engine. Thanks in advanced for your help.
JMS/MN
10-05-2005 21:30:52
 Re: D17 Rear Main Seal in reply to gh in oh, 10-05-2005 09:17:39
Do a search in the archives here, maybe Rod from NH, WD45 rear seal. Used a wire and plastic strips to pull the new seal through. I saved pix of it.
airdefender
10-05-2005 20:21:52
Does you D17 have 3 point? if not can it be made into one? Thanks. John
Don Holden
10-05-2005 14:53:54
Yes, you've got to split the tractor. Be sure you get the adhesive that is recommended when installing the new seal. I believe it is marketed by 3M. Take your time, do it right, and you will be pleased with the results. I know it is annoying and It is something that happens to these D17's. I did mine a couple of years ago, and I am happy to say it is still working great with no leaks. Don Holden
BCnT
10-05-2005 10:33:15
my manual says ya gotta pull motor,flywheel,etc...its 1 piece seal...lovely...just lovely...diesel same way
