WD45 Carb Problem?
Paul D.
10-04-2005 17:23:47
I've had my WD45 for the last 6 months. I've putted around the field and plowed up/disced a small garden spot for next year. The tractor has purred like a kitten. I plowed up a very rough rough, rocky acre for a buddy to put in a food plot for deer. The tractor saw wide open conditions and an extended period of operation, 7 hours. The tractor began to cut out and miss like it wasn't geting gas, I'd pull the choke out and it would stabilize momentarily. I got it home, cleaned out the sediment bowl which had a little bit of water and a few pieces of rust (nothing major). I cleaned out the gas tank, examined the inside and saw no rust that would alarm me. I took the carb apart and cleaned it although it wasn't that dirty. I put in new plugs and the tractor starts ok but runs terrible! It runs very rough, I have to feather the choke at times to keep it going and then it quits. Blows black smoke when I try to start it and eventually quits and I can't start it. Don't know what the exact settings should be on the screw on te bottom of the bowl or the idle screw. I've also noticed considerable moisture forming on the outside of the venturi area where the carb bolts onto the manifold. I don't recall this earlier in the summer. My next move is to use an external fuel source to rule out the tank/sediment bowl/gas line. Any one have an idea where I should go next? What would cause a smooth running WD to turn into such a problem? HELP!?
mlpankey
10-06-2005 22:26:29
 Re: WD45 Carb Problem? in reply to Paul D., 10-04-2005 17:23:47
my wd pulling tractor did the same way . the fix was to take carb apart clean in a carburator cleaning solution for several hours and reassemble. see the reason you have to choke it is to turn the air off so that the small amount of gas the engine is seeing can burn without beeing blown out
Glider
10-07-2005 05:56:56
 Re: WD45 Carb Problem? in reply to mlpankey, 10-06-2005 22:26:29
I removed automotive fuel filter and cleaned carb . Turned out to be load adjusting screw , why did it just change overnight ? it seemed tight
BCnT
10-05-2005 08:13:00
sounds like ignition to me...more n likely coil...you said you replaced plugs...what did they look like and did you replace with a different brand/type...it do make a difference.
jeffalex2
10-04-2005 18:33:21
The manuals say to start with preliminary adjustments of one full turn off of seat...but usually unless these screws are way off, the tractor will still run half way decent as long as they are not under load. You've got something causing this tractor to go WAY rich. Extreme service like you described will shake alot of stuff loose on a 50yr old machine. If you don't find anything obvious at the air intake, you may want to do a compression check or watch to make sure the oil press guage doesn't vibrate alot more than usual. When it does run or while cranking, take the radiator cap off and make sure that coolant doesn't jump out of the radiator. This will make sure you don't have a serious valve or gasket issue.
Glider
10-04-2005 18:20:39
My WD45 ran perfect, I went to a antique tractor pull (1st time ) and was in a practice run. I hit the throttle with great expectations, and was hopless less than half way down the track, I had to choke it to load and take home. cleaned carb and removed air filter tube to no avail. Been busy, but coil was next. Maybe bending the float for more gas? My tank is clean and I have a automotive type fuel filter. Please let me know if you find and easy fix!
Did I mention that it WAS tuned to perfection !!
buford
10-05-2005 18:10:13
 Re: WD45 Carb Problem? in reply to Glider, 10-04-2005 18:20:39
I had the same problem with the auto filter seems that the auto filter has to have fuel pump pressure for full flow,I found a filter for a lawn mower that works for me hope this helps lawnmower was gravity flow like the wd45
Terry(GA)
10-04-2005 17:55:54
Sounds like it maybe flooding.Make sure the manifold is not leaking,also try starting it with the air cleaner hose disconnected.If the air cleaner is stopped up it will cause big problems.Good luck!
