Crank Pully
Dave Black
10-04-2005 15:35:59
I have a ac wc 33 need to remove the timing cover to get the broken pieces of the govenor weights out, I removed the oil pan, to see it the pieces fell down, they didnt. Removed the crank pully set screw, and the pully wont budge, the pully doesnt have a center hand crank center bolt, hand crank groves are part of the pully. help!
Dave Black
10-23-2005 20:23:24
 Re: Crank Pully in reply to Dave Black, 10-04-2005 15:35:59
Thanks Denny, I just got my welding tanks filled, Im going to add heat to the out side of the pully while using a home made slam puller, I have soaked the set screw hole with penitration lube, let it soak for a week, now come the test. I'll let you know.
Texas Denny
10-06-2005 07:39:13
I've removed them a couple of times from WD tractors about 15 to 18 years newer. It comes off hard, I remember. I couldn't remember how I did it exactly so I didn't respond when you asked your question. I think the best would be a slide hammer puller. But who has one of them? Could you use it in the confined space without pulling the engine? I think that I just soaked the shaft in a lubricating penetrant (not WD-40) and kept tapping on it with a hammer while pulling at same time. I don't think there are any tapped wholes on this pulley that you could use with a puller. However, you could add a couple of 1/4-20 or 5/16-18 tapped holes so you could use a puller. May have to pull the engine to do it unless you have a right angle drill. But then, can you get a puler in there without pulling the engine? You may have to make a puller as well.
Dave Black
10-28-2005 14:30:47
 Re: Crank Pully in reply to Texas Denny, 10-06-2005 07:39:13
Well I have some great news, I got the pully off with the help of two ball joint splitters. I had a extra set of hands. We had the fork of the splitter stradling the timing cover ridge around the front crank seal. I am planning to drill and tap two stearing puller holes.
Thanks Denny
