AC WD Low Compression on 2 and 3 cyl.
ron bond
10-03-2005 13:16:30
I finally got my WD going and found that the no. 2 and 3 cyl's are not firing. The compression is no.1-105, 2-45, 3-45 and 4-105. I hope that one of you could help. The tractor sat for 3 or 4 yrs. I don't know if valves are stuck or a head gasket is blown between 2 and 3.
I need some help .
thanks- ron
Texas Denny
10-03-2005 18:19:10
 Re: AC WD Low Compression on 2 and 3 cyl. in reply to ron bond, 10-03-2005 13:16:30
Talk to the guy that ran it last. If it ran good four years ago, burned valves won't be the problem. Probably the head gasket is OK too. Stuck rings would seem the most likely.
Texas Denny
10-03-2005 18:21:43
 Re: AC WD Low Compression on 2 and 3 cyl. in reply to Texas Denny, 10-03-2005 18:19:10
Sometimes times they loosen up from use - getting warm and cold. A soak in a lubricant as suggested by "old" shouldn't hurt anything. Change oil afterwards.
old
10-03-2005 18:55:03
 Re: AC WD Low Compression on 2 and 3 cyl. in reply to Texas Denny, 10-03-2005 18:21:43
Hey Tex, the tranny fluid and getting them a little hot has worked for me so many times I have lost count. But then on the other hand some poeple call me crazy when I do what I do and some just keep bringing there engines back every time they have problems. LOL
old
10-03-2005 14:23:59
Rings maybe stuck on those cylinders. I'd fill the cylinders with tranny fluid and let it sit a day or 2. I also when haveing that trouble will drain the rad and let it run for 5-10 minutes and shut it off after doing the tranny fluid. That gets the engine good and warm but not to hot and lets the rings etc loosen up.
TexasAllis
10-03-2005 14:12:23
The valves could be stuck or burned and the head gasket blown. My D-17 had the same symptoms had a blown gasket and burned valves. It sounds like the gasket is blown between the cylinders. I would not try to re-torque the head. Pull it and fix it. Gaskets are cheap. I had my D-17 head reworked new exhaust valves and milled for $130.00. Well worth it.
Good luck
Worth Golightly
