WD 45
HOBO
10-02-2005 16:20:45
NEED HELP! Newly rebuilt engine barely turns over.
Starter turns engine over with plugs removed.
Everything else has been checked. Any ideas? Thank You.
Texas Denny
10-03-2005 06:15:20
 Re: WD 45 in reply to HOBO, 10-02-2005 16:20:45
Who rebuilt the engine? The WD had adjustable bearings with shims. I believe the WD-45 is the same (at least my book doesn't show a difference). If bearings were replaced, the bearings must be adjusted by adding or removing shims. Plasti-Gauge is used to determine the clearance. After each bearing is assembled, the crank should be turned to insure that there isn't binding. This has to be done on the rod bearing as well as the mains.
The rear main seal is a trial and error affair. More material is provided than is needed. If you stuff the whole thing in there, I discovered that the seal was so tight I couldn't turn the crank. So you need to pull some of the seal and cut off a little bit until the seal drag is not large. An improper seal installation will freeze a crank without pistons and rods attached.
Before putting in the pistons, it is also a good idea to put the new compression rings in the cylinder to see that there is at least 0.001 clearance at the ring joint. It is rare that this could be a problem (maybe even impossible) but I like to check it to be sure.
Good luck.
