CA Hand Clutch Assembly Needed
OrangeDP
10-02-2005 15:21:02
Anybody know where I could get the hand clutch assembly for a 1952 CA? What do you think they should cost? Thanks in advance for your help with this!
Michael D.
10-03-2005 15:49:17
 Re: CA Hand Clutch Assembly Needed in reply to OrangeDP, 10-02-2005 15:21:02
I found one on ebay last spring. We are going to pull the the one off the tractor this winter and replace it. Alot of the time they just need a good cleaning and new clutch disc. Parts to rebuild them can be found but expencive. The one in my tractor now had been welded so i dont think it is any good. You can plan on spending $100-$150+ on ebay as they are hard to find and hope you get a good one. I have all the part #"s and breakdown of the clutch. If you need help I will do my best from a distance just drop me a line my email is open.
boyd oakley
10-04-2005 02:30:47
 Re: CA Hand Clutch Assembly Needed in reply to Michael D., 10-03-2005 15:49:17
I HAD TO REMOVE MY HAND CLUTCH AND IT WAS DAMAGED GETTING IT OFF. I'M WOUNDERING IF YOU COULD REPLACE IT WITH A LEFT SIDE AXLE AND DO AWAY WITH IT , THE DIFFERENIAL DOES NOT LOOK LIKE IT WOULD BE POSITIVE TRACTION,KEEPING THE TRACTOR FROM TURNING ? BUT I KNOW SOMEONE THAT HAS A CLUTCH ASSY. IF THEY CAN GET IT OFF.
