D12 battery connections
jerry l
10-02-2005 12:05:24
is the D12 postive ground cant seem to get any spark at the plugs
chalmersbob
10-02-2005 17:39:39
 Re: D12 battery connections in reply to jerry l, 10-02-2005 12:05:24
make sure you are getting voltage to the coil first. BOB
old
10-02-2005 12:41:08
How its grounded will not do much as far as spark you will have it either way. If it has a genny its probably positive ground. If you have an altenator it will be negative ground. Your spark problem is most likely to be bad points or condenser. I'd do a full tune up on it. Points, plugs, and condenser.
