Thompson equipment wheels
jim Bradley
10-02-2005 07:51:23
I see a WD for sale, high crop, it says Thompson equipment wheels. What are they? off some other equipment? standard to AC WD? Also, were there any high crop D-17s?
ACEd
10-02-2005 16:12:00
 Re: Thompson equipment wheels in reply to jim Bradley, 10-02-2005 07:51:23
Thomson (Louisiana) made high crop variants based on AC UC, WC, WD, WD45, D17 as well as the smaller models. They are pretty collectable if correct. Frequently the primary difference was the addition of taller wheels - generally 36" or 38" rears replacing the more common 28" wheels and most often 21" fronts with long kingpins. There were also some additional points such as modified plow lifts and the WD had a centered seat rather than standard offset configuration. Most common rear wheel configuration in my experience is the stock AC 36" or 38" rear centers P/N is U-4010 I believe for the 36" I have on my WC and WD, but Thomson used their own front centers for the 21" rims as well as some of the rear wheel centers that were cast for them and have Thomson incorporated in the casting. The WC thru D17 Thomsons were imbedded in normal production sequence and may have been shipped less wheels, so it is very difficult to distinguish - other than they were generally diesel in D17 and K (Kerosene or distillate) in earlier tractors and as far as I know all were adjustable front including a group of 1946-48 WC's with 16" rim config from WF.
