A-C wheel weight ID
Gary/MD
10-02-2005 05:22:54
Trying to ID rear wheel weights,have seen these at shows but could not find a part # on them. Ebay # 7548397664,B with weights on rear. Ebay # 7548805494,WD with weights on rear. Are these weights A-C factory and are they the same part? Knowing this would make locating these weights much easier. Gary/MD
W4
10-04-2005 05:54:44
 Re: A-C wheel weight ID in reply to Gary/MD, 10-02-2005 05:22:54
I just went out in the garage and checked the two 100# wheel weights that were left over from our old AC-C.They are 17 1/2" in diameter, and have AM 3138-4 casted into the back side of the weight. There is also an X casted just below the 31. These fit a C or B and probably a CA. They go on the INSIDE of the wheel.I hope this helps.W4
chalmersbob
10-02-2005 17:50:37
the weights on the wd look like the same weight as they have the same 4 cutouts. BOB
chalmersbob
10-02-2005 17:46:45
the wheel weights on the b are the standard b weights. notice the 4 cutouts for the wheel clamps.BOB
Eldon (WA)
10-02-2005 09:13:11
Original AC weights will have a number cast in them that starts with "AM". B and WD/WD45 weights are both listed at 142# so they may be the same, I haven't checked the casting #s. Smaller 100# weights were also available for the B.
Texas Denny
10-02-2005 08:00:23
Gary. I think that they are the same. The B wheel is a 24" and the WD/WD-45 wheel is 28". You'll notice how the weight on the B virtually fills the whole wheel while there is a couple of inches of space on the radius for the WD-45. I think those are WD weights on the B. Other weights I've seen on B and C tractors were smaller in diameter. What you need is a wheel weight diameter. I don't have it but maybe someone else does. Later in the week, I am going to my ranch and could measure it then and respond.
