John T
10-01-2005 19:55:41
Re: Starter in reply to Mark Millhoff, 10-01-2005 17:35:02
Mark, im unsure if thats a mechanical push start switch?? But if so, first thing is to insure its pushing the button tight n down all the way,,,,, ,,,,, ,if so, next remove the cable n clean n wire brush everything n reattach n tighten n try again,,,,, ,,,,if she still arcs theres a good chance EITHER the switch contactor is all burned n carboned up (needs new switch) or else the post out of the starter (what switch contactor touches) is all burned n pitted. If the switch contactor is all burned n carboned you may well need a new switch. If the starter post is pitted, I have had some luck cleaning n light filing them then they worked. Otherwise it may need a new starter post. Also check the grounds and remove n clean n wire brush n reattach each n every battery n starter n ground cable cuz a bad connection anywhere can cause a problem. John T
