D-14 stater problems
dan
07-21-1999 13:13:19
I HAVE A D-14 WITH SOME STATER PROBLEMS! THE TRACTOR HAS BEEN CONVERTED TO A 12-VOLT SYSTEM, AND IT STILL HAS THE ORGINAL 6 VOLT STARTER. I HAVE HAD THE STARTER REBUILT AND THE PROBLEM IS THIS. SOMETIMES WHEN I TRY TO START THE TRACTOR THE STARTER WILL JUST SPIN AND NOT INGAGE, THEN WHEN I TRY AGAIN IT WILL ENGAGE AND IT WILL START FINE. THIS HAPPENS ABOUT 50% OF THE TIME. I HAVE LOOKED AT THE FLY WHEEL TEETH AND THEY DO NOT SHOW ANY ABNORMAL WEAR OR HAVE ANY BROKEN TEETH OR ANYTHING LIKE THAT. SO IF ANYBODY HAS ANY SUGGESTIONS, I WOULD BE OPEN TO HERE FROM YOU. PUZZLEED IN MISSOURI!
Rick
07-22-1999 03:56:00
 Re: d-14 stater problems in reply to dan, 07-21-1999 13:13:19
Jackson is correct it sounds like the bendix. Since your tractor has been converted to 12 volt you can replace the 6v starter with a D15 12v starter once your old 6v peters out. But I would milk the old one as long a I could. Good Luck!
Jackson
07-21-1999 15:41:23
dan,pull the starter and replce the bendix.the same thing happened to me on my 14 and that solved the problem. Jackson
