wd45 lift
jeff duckett
09-30-2005 13:09:10
the lift on mywd45 isehter all the wayup or alltheway down whats wrong an what oil should in the lift. thanks
Butch(OH)
09-30-2005 17:52:21
 Re: wd45 lift in reply to jeff duckett, 09-30-2005 13:09:10
Yes you are set up for drawbar control aka traction booster, aka draft control. I cant explain the knobs and things that need to be turned in or out well enough for you to find them. You need a operators book as suggested or the directions are on a decal that is supposes to be on the battery box.
JMS/MN
09-30-2005 16:32:07
There are four handwheels/screws on the pump and valve on the WD45. All of the various settings are detailed in the operator manual for the tractor, along with correct oils to use, according to ambient operating temperatures that the tractor may be used in, as well as other pertinent information for proper operation, lube, and service.
Zonie
10-02-2005 21:31:20
 Re: wd45 lift in reply to JMS/MN, 09-30-2005 16:32:07
Here'd a link to some very good information including the hydraulic operating instructions. Save it to your favorite places, You'll refer to it again and again.
