D 17
44JIM
09-30-2005 04:57:01
GOING TO GET A TRACTOR SOON TO WORK ON THIS WINTER AND FOUND A D 17 ALLIS WHICH SEEMS TO BE PRICED OK. THE TRACTOR IS ONE OF THE EARLY MODELS WITH THE SNAP COUPLER HITCH AND IT DOES HAVE THE DRAWBAR. THE TIN IS GOOD AND NOT RUSTY AT ALL. IT HAS SET FOR MOST OF 5 YEARS EXCEPT TO MOVE AROUND, AND BLOWS BLUE SMOKE WHEN STARTED. DOES NOT HAVE POWER ADJUST REAR WHEELS, PRESSED STEEL. I KNOW THIS HURTS THE VALUE. POWER STEERING, GOOD RUBBER ALL AROUND, METAL DECALS ON THE HOOD EACH SIDE, CLUTCH AND POWER DIRECTER WORK OK. ONLY 12 MILES FROM HOME.ANY CHANCE THE RINGS ARE STUCK AND CAN BE LOOSENED UP OR IS IT A DEFINITE OVERHAUL? I APPRECIATE ANY ADVICE.
John (MO)
09-30-2005 05:41:30
 Re: D 17 in reply to 44JIM, 09-30-2005 04:57:01
I think it"s going to be pretty hard to say until you run it a little while and see. I think I"d try using a little mystery oil in the gas for the first couple of tanks. That should help if it"s rings. You could do a couple different compression tests but I"m not sure that will tell you what the problem is, just that there is one. I wouldn"t take her apart until I"d run her several hours to see if the rings might be the problem and correct themselves.
