AC B hydraulic pump
Weslyn Stewart
09-28-2005 05:51:57
I have a 1940 AC B with hydraulic pump on the pto. Where can I get a seal kit adn possably a breakdown of the pump???
Texas Denny
09-28-2005 07:01:40
 Re: AC B hydraulic pump in reply to Weslyn Stewart, 09-28-2005 05:51:57
Try an Agco dealer for parts.
I have a copy of an exploded view of the pump. It's not perfectly clear but you can make out everything. Send me an email and I'll email it to you.
If the reason you want a "seal kit" is because it drifts down under load, the spools in the valve do not have o-rings. They depend on seal due to close tolerance.
When I went through my CA (it is different than the C), I decided the only way to make it work like new was to rebore the the pump body and make new oversize spools. Of course, that is a very time consuming task for an amateur machinist. So I developed a mechanical means to prevent drift down. I used a 2x2 square tube that was adjustable up and down. The lift arms sat on the tube when down so my mower height didn't vary. On a WD, I used chains over the rear axel. On my C, I used chains from the upper to lower lift arms and just took out links until the mower was the right height. On a Ford, we ran chains from the lower lift arm to the three point clamp. There are lots of low cost ways to compensate for a tired control valve.
Weslyn
09-28-2005 08:11:12
 Re: AC B hydraulic pump in reply to Texas Denny, 09-28-2005 07:01:40
Is there a Agco dealer in or near Fort Worth, Texas?
Texas Denny
09-28-2005 10:01:34
 Re: AC B hydraulic pump in reply to Weslyn, 09-28-2005 08:11:12
The closest that I know of is just north of Hillsburo, TX on IH-35. Call before you go there to make sure they can Help on Allis. I go to Blackland Impl. in Temple, TX.
HILL COUNTY IMPL. CO. INC
I-35 P. O. BOX 784
HILLSBORO, TX 76645
254-582-8473
JMS/MN
09-28-2005 08:31:41
Try the dealer locator at www.agcocorp.com.
