Allis B Missing
jeffalex2
09-27-2005 18:59:54
My Allis B with FMJ Magneto will run fine for a couple of hours, then start missing. If I clean the spark plugs, then it's fine again. It doesn't smoke, or use oil, yet it appears that the plugs keep partially fouling...
Any Ideas??
Thanks
Tyler from UT
09-27-2005 21:06:45
 Re: Allis B Missing in reply to jeffalex2, 09-27-2005 18:59:54
Could try and see if a hotter plug helps.
old
09-27-2005 19:13:25
Mag coil is probably getting weak. As it runs the coil gets hot and stops putting out a good blue spark and then it fouls the plugs. When it does that pull one plug wire and check the spark to see if its a good blue spark or if its a bad yellow spark. Almost bet you will find a yellow spark which will run it but not very well
jefalex2
09-28-2005 03:39:51
 Re: Allis B Missing in reply to old, 09-27-2005 19:13:25
OK - before I get a rebuilt magneto, what is the best plug to run in this ol' tractor...?
Steve in N.J.
09-29-2005 17:58:19
 Re: Allis B Missing in reply to jefalex2, 09-28-2005 03:39:51
Also, on your "J" model mag, Fairbanks used a tar-taped style coil in the eariler model "J" series mags. These coils tend to leak as they get older and been in service for many years. Coils do change their intensity as they get hotter under working conditions, and the older tar-taped coils would ground themselves to the inside of the mag housing and either shut the engine down, or cause the engine to develop a miss. Eventually the coil fails. We have all Fairbanks mag parts in stock since we rebuild, service, and repair all mags. F/M's are our specialty. Drop us a line or give us a call be glad to help ya out with any info or tips on your mag....
Steve@B&B
(973)697-5747
Steve in N.J.
09-29-2005 17:50:07
We were just talking about spark plugs a few posts up. The Autolite 295 plugs work nice as well as the NGK B4 & B6S equivalents. If you can't find them locally, we have em' in stock. Steve@B&B
old
09-28-2005 06:04:02
Can't tell you that its been a few years since I have had one of those. An Allis B was the first tractor engine I ever rebuilt and that was when I was 18 and thats been a few decades ago.
farmerwannabe
09-28-2005 07:15:29
 Re: Allis B Missing in reply to old, 09-28-2005 06:04:02
Old...seems you still remeber an aweful lot about B"s for having worked on one so long ago. Out of curiosity, what tractors have you, or do you, owned? I know you"ve given me great advice when I owned a Ford 9N last year. (great tractor, but I"m enjoying the heck out of this AC B...those lift pin leaks just got the best of me)
old
09-28-2005 09:09:48
 Re: Allis B Missing in reply to farmerwannabe, 09-28-2005 07:15:29
Well at this time I have 5 olivers 2 farmalls 2 allises, 2 JDs, 2 MHs, 3 fords, a galion road grader, a cat 950 loader and a bob cat. I've sold some where are 10 differant ones in the last few years. Most of these that I have I've either done a lot of work on or got them in nonrunning condition. Oldest I have is a JD-B which is a 1935 on steel and I know its history all the way back to 1940. The newest I have is a 1967.
farmerwannabe
09-28-2005 12:18:05
 Re: Allis B Missing in reply to old, 09-28-2005 09:09:48
Wow! That"s a great collection. How"d you end up deciding on those to keep?
old
09-28-2005 15:08:18
 Re: Allis B Missing in reply to farmerwannabe, 09-28-2005 12:18:05
Well at this time only a few of them are keepers. I have a Farmall H, an Oliver 77, A MH 101SR and an 8N for sale. I also keep 5 tractors a friend owns running for him.
