AC Model M questions
Ralph B
09-27-2005 18:41:27
I have an AC Model M. 1) It has a 12V positive ground starter in it marked "Autolite MAB4046" on the tag. Anyone know what wire size I should use to feed this or how many amps it draws? I currently have a 6 guage wire, but worry if it's big enough.
2) Can anyone tell me where to find the serial number? Apparently I need that to order a parts manual.
Texas Denny
09-27-2005 19:10:45
 Re: AC Model M questions in reply to Ralph B, 09-27-2005 18:41:27
I suggest 4 AWG or larger. 6 is on the low side but may work acceptably if all the connections are fresh, clean and free of acid and the cable lengths are short. Can't help on serial number.
Ralph B
09-29-2005 16:17:33
 Re: AC Model M questions in reply to Texas Denny, 09-27-2005 19:10:45
Thanks for the advise. I think I'll go 4, since the run is about 5' from the start switch..
Texas Denny
09-30-2005 20:13:39
 Re: AC Model M questions in reply to Ralph B, 09-29-2005 16:17:33
I didn't know there was that much wire in the system. If it is over 5' total (ground cable + cable to switch, + cable from switch to starter), 4 is a little marginal. 2 AWG would be safe.
