1947 AC Model B
Ronne B Goode
09-27-2005 11:19:00
Where is it located and how do you change the oil pump.
steve(ill)
09-27-2005 18:23:49
 Re: 1947 AC Model B in reply to Ronne B Goode, 09-27-2005 11:19:00
if you are talking about the motor lube pump, it is bolted to the outside of the motor, infront of the flywheel and clutch. you need to split the tractor motor from the torque tube and roll the front end forward a couple feet so you can get into the flywheel area.--
-- if you are on the hydraulic pump, it is at the right rear corner of the pto, attached to the hydraulic valve and sticks inside the pto housing. held in by 4 bolts.
JMS/MN
09-27-2005 11:38:10
Inside the crankcase. Two bolts?
chalmersbob
09-27-2005 19:09:41
 Re: 1947 AC Model B in reply to JMS/MN, 09-27-2005 11:38:10
jms
wrong model
bob
