rear wheel size
corncobb
09-26-2005 15:50:13
just brought home a 1937 wc, the back tire/wheels are 13.6x28 cut spoke. I will be restoring this tractor back to stock and need this info. for now and alot in the furture.
Thanks alotC.Cobb
Texas Denny
09-26-2005 21:30:13
 Re: rear wheel size in reply to corncobb, 09-26-2005 15:50:13
If you are restoring to stock, it had steel wheels on it.
If you want it with rubber, Allis made two stock wheels. One used 11x28 tires and the other used 13x24 tires. The 11x28 used a cast steel wheel that was about 1" thick that could have the rim in several positions. The 13x24 had a stamped steel non adjustable rim (other than spinning around). I don't know the rim width of either one. My WC has the 11x28 version. I could measure the rim width for you, if you like.
acmfmh
09-27-2005 18:19:07
 Re: rear wheel size in reply to Texas Denny, 09-26-2005 21:30:13
I have a set of each for a WC. The 28inch wheels are 10inches wide. The 24inch wheels measure 9inches wide.
corncobb
09-27-2005 16:52:39
If you would measure a rim I would appreciate it.
Another thought is what size do pulling clubs like to see I'ld like to try a antique tractor pull.
Sorry of I ask to many questions I'm lnew to this, I've seenantique tractor pulls want to do it,
Thanks Cobb
Texas Denny
09-27-2005 18:27:57
 Re: rear wheel size in reply to corncobb, 09-27-2005 16:52:39
I'll measure it on Thursday and give measurement when I return on Friday.
