Allis B Timing Part 2
jeffalex2
09-24-2005 17:28:30
Timing's fixed...runnin' like a top again!
Today I put on new rear rubber and replaced the brake bands. Is it normal for new bands to be super tight? So tight that you can't adjust out enough to set parking brake? I got them thru OK Tractor and they look right. Tractor stops real good, just can't set the parking brake.
Any Thoughts?
chalmersbob
09-24-2005 18:12:44
 Re: Allis B Timing Part 2 in reply to jeffalex2, 09-24-2005 17:28:30
should be enough play to adjust so the parking brake works.
jeffalex2
09-25-2005 03:36:14
 Re: Allis B Timing Part 2 in reply to chalmersbob, 09-24-2005 18:12:44
Problem is, when I back the screws out enough to get the parking brake cams to work, the screws pop out of the bands...either the bands have to stretch or i'll have to get longer screws.
