allis b mower ???
ed in cny
09-22-2005 19:17:04
I have what I believe is an Allis CA bar mower. I would like to mount it to my Allis B. Is there any problem with mounting the mower or will it work at all. It has the two belt pully on the back of the mower and the manuel for the B showes a single. Someone also pointed out the front mounting bars are bent for the CA. Could anyone help with this. I would like to use it this next summer but must get the kinks out now. Thanks
Jerry Coulter
09-24-2005 14:16:55
 Re: allis b mower ??? in reply to ed in cny, 09-22-2005 19:17:04
The #5 mower made for the CA was adaptable to the B & C tractors. There was some difference in the hydraulic lift mechanism which you may have to work out, if you have manual lift that would be no problem. Since CA and late B has the one and three-eights PTO spline, you may have to obtain one of those reducer spline bushings if your tractor has the one and one-eighth spline. You may need different length belts. Don't fail to install the turnbuckle stiffeners from the drawbar to the seat rails.
steve(ill)
09-23-2005 18:09:07
ed, i can tell you all the details, but the original tractor was a B, then few changes to a C, then updated to a CA. they use the same motor and torque tube design. the final drives on a CA are kicked out and backward a little bit so it is a few inches longer. I think the sickle mower would be very close to fitting. as you noted the brackets or mounts will be different, but the main unit will be about the right size. i think a little modification by yourself or local shop would not be difficult. if it has 1 or 2 idlers that is not important, it is in the design of the unit. both tractors have rear PTO and belt shaft PTO very similar in design adn location.
