WD Power wheels
Larry Paz
09-22-2005 11:55:38
I need to adjust the rear wheel width on my WD, so I can put it on my trailer. How does the power wheel thing work? I never used this feature before, so any tips would be appreciated. I do see there are three bolts that seem to go on the rim and the hub. Are these bolts what I need to take loose? And do I just loosen them or do they have to come all the way out?
Another guy I talked to said there were some pins you have to pull, but he was talking about his Oliver. I don't see any pins on this WD.
Bushogpapa
09-22-2005 17:52:36
 Re: WD Power wheels in reply to Larry Paz, 09-22-2005 11:55:38
Try to lossen the one that is on top, first...that one has no weight on it, and will turn the easiest...may have to soak them with penetrant, butonce moved and oiled they seem to work easier.. Tighten them bottom to top is the easiest.. Once loose, hold the opposite brake and ease out on the clutch either in reverse or 1st to move the wheel in or out.. Have one "stop" in place to stop the wheel where you want it.... Ron.
John (MO)
09-22-2005 13:32:32
There are 3 or sometimes 4 eccentrics on each wheel. They are square headed and have a protrusion under the head that will keep them from turning all the way around. You need to turn the eccentrics counterclockwise as far as possible to loosen them. This may require soaking, heat, long cheater bar or all three depending on how tight they are stuck. Then on one of the rails on each wheel, there should be stops on both sides of the eccentric. These will also need to be romoved. Once everything is loose and the stops are removed, forward or backward movement of the axle will cause the wheels to adjust in and out by way of the rails. I find it"s easiest to do one wheel at a time, then tighten it back up before loosening the other.
JMS/MN
09-23-2005 07:31:55
 Re: WD Power wheels in reply to John (MO), 09-22-2005 13:32:32
On the WD there are 4 eccentrics, and they are hex-headed. I've never seen power-shift wheels of any manufacture with fewer than 4- larger tractors use more than 4.
