Help with Bull Dozer
philip1
09-21-2005 12:43:37
have an 1955? dozer with a clutch problem.
Model = HD5B 5151
Engin s/n = 2A2871
I needed the clutch adjusted and had one of the older mechanics look at it. Found out he wasn"t as good as he said he was.
problem: there is two slotted screws and one bolt holding on the outside retainer cover to the adjusting ring where you would pry the teeth to adjust the clutch.
The slotted screws were losed by mistake and now we can"t tighten them. In the manual it says "do not losen the slotted screws" but I guess he wasn"t reading it right.
Now we have the two slotted screws and the single bolt lose and still did not adjust the clutch and can"t tighten them up.
Question: What are the "slotted screws for"?
Is there a way to tighten them without removing the adjusting plate?
What is the screws/bolts needed to adj. the clutch
properly?
Any help would be apprieciated here in CT.
hector gemme
09-21-2005 16:25:04
 Re: Help with Bull Dozer in reply to philip1, 09-21-2005 12:43:37
HI I told you a week pass the two screw are loose their and you can not tight them becausetheir is a nut inside with hole cutterpine .For adjuste your cluch you have to loose the bolt and with a screw driver you will see some small teeth being the plate just prage in the hole plate the teeth to turne adjustement plate just little and check your arm cluch and if oke dont forget lock the bolt.IF IT NOT WORK SEND ME A �-MAIL.HECTOR
