ID of a tractor
Polk Crawler
09-20-2005 14:16:21
Nearby a 4 cyl, 3 spd, light tractor, orange in color, has belt pulley and PTO under the seat behind the rear axle casing, has a one bottom plow attached to a forward drawbar. Only clue as to identity is what appears to be a serial number located near the base of the gear shift lever. No other ID plate of any kind on it. Serial No is 3102992 Color, if original, appears to be orange. Would appreciate info on model,year, and approximate value. Thanks PC
Joe(TX)
09-21-2005 05:14:36
 Re: ID of a tractor in reply to Polk Crawler, 09-20-2005 14:16:21
If the 3 is a B, then it is a 1950. Would be an adjustable wide front, none row tractor
Texas Denny
09-20-2005 19:55:24
I think "old" is right on. Allis never had a serial number with 7 digits. I think the biggest number ever was less than 180,000 on the WC. The 3 must be a B.
old
09-20-2005 20:32:52
 Re: ID of a tractor in reply to Texas Denny, 09-20-2005 19:55:24
Hey Texas, I got all the decals on and its ready to go to the show. Probably don't have them on right but close I hope.
Texas Denny
09-21-2005 06:44:39
 Re: ID of a tractor in reply to old, 09-20-2005 20:32:52
Congratulations!
old
09-20-2005 14:40:46
Sounds like a B Allis but not sure. Could that 3 be a B instead of a 3?? Most numbers on Allis tractor have the model number before the serail number.
Polk Crawler
09-21-2005 10:11:38
 Re: ID of a tractor in reply to old, 09-20-2005 14:40:46
OLD: Could be a B rather than a 3. Serial no is pretty cruddy. If I did a little scrubbing a B might show up.
Thanks to you and the others for the lead.
PC
