Won't Start..Help Please
Tip
09-20-2005 06:37:05
Turns over won't start. Not enough fire. Need to know Gap setting on Points..Looks like has new carburator, coil..been sitting a couple of years..Turns over with a 6 volt battery. Started says 12 volt. Does it have to have a 12 volt Battery? Serial number is 035288,,Would like to know year made to find a proper manual..It's about the size of a riding mower. Has Big Ten plate on side. But can't find one that looks like it..Any help would be greatly appreciated.
Can E-mail pic.
BCnT
09-20-2005 10:11:47
 Re: Won't Start..Help Please in reply to Tip, 09-20-2005 06:37:05
like old said...if starter says 12 volts then starter AND coil need 12 volts. i've got a small engine repair shop and anytime i'm not sure of point gap on older machines i use .015 .it works on 98%...also just because carb and coil look new dont take for granted they are in good shape...especially carb...todays fuel really clogs stuff up even after a few months let alone a couple years...you can use carb cleaner to spray like starting fluid to see if it will fire...its alot safer than ether...also can jump off your car or pickup battery but disconnect that 6 volt battery first and dont start donor vehicle...just use battery power.
also look around for brand name on engine...chances are its a briggs,tecumseh,wisconsin,etc. if its a garden tractor
souNdguy
09-22-2005 21:19:41
 Re: Won't Start..Help Please in reply to BCnT, 09-20-2005 10:11:47
Yep.. and when in doubt.. a business card or match book cover.. or a flap from the points box usually sets darn close to .015
Soundguy
TIp
09-20-2005 15:45:16
Thank you guys for you help..Got a 12 volt Battery and cleaned the points and it fired right up!!! Yeah! The engine is Briggs..
BCnT
09-20-2005 16:55:04
 cool...glad ya got it *** in reply to TIp, 09-20-2005 15:45:16
nt
old
09-20-2005 08:14:55
If the starter says 12 volt on it yopu need 12 volts to spin it the way it should and also to keep from burning it out
