D-14
cody
06-13-1998 13:03:41
i have a 1957 d-14, it keeps popping out of 3rd gear going down a hill.under a load it stays in.i also cant get 2nd gear to stay in at all.is this going to be expensive?thanks for your help.
grapeape
06-14-1998 15:32:50
 Re: d-14 in reply to cody, 06-13-1998 13:03:41
: i have a 1957 d-14, it keeps popping out of 3rd gear going down a hill.under a load it stays in.i also cant get 2nd gear to stay in at all.is this going to be expensive?thanks for your help.
yes, it probably is gonna be expensive. if youre lucky, it might be a problem in the shift rails, like a bent fork. you can take the shift cover off and check this. if you remove the shift cover, be sure its in second gear before you lift it out. all allis transmission covers need to be in second for easy removal and installation. if its not bent rails, it will more than likely be second and third gears and the shift collars for those gears, and they are high. good luck, grapeape
