No Hand Clutch on my CA
RogerS
09-19-2005 08:36:36
My "new" 1956 CA doesn't have a hand clutch handle. I made a make shift handle and when I tried to use the clutch it did nothing. I haven't tried adjusting it yet, but I was wondering if anyone could tell me how hard a hand clutch replacement is should I need to do it. Are the parts readily available?
Texas Denny
09-19-2005 20:17:24
 Re: No Hand Clutch on my CA in reply to RogerS, 09-19-2005 08:36:36
As BCnT says, it seems like the clutch disk is stuck to the pressure plates. You may try holding it back in disengage position with it stopped, then release the foot clutch repeatedly. The pressure of starting might break it loose. If it doesn't break loose, you'll need to disassemble it and clean it up. I can send you some info.
RogerS
09-19-2005 08:59:09
I have read some comments on this forum. Most have indicated that when they installed a handle they couldn't pull it back. Mine pulls back the full range, but the clutch is always engaged. The handle springs back forward on its own.
BCnT
09-19-2005 09:24:38
 Re: No Hand Clutch on my CA in reply to RogerS, 09-19-2005 08:59:09
the clutch disc could be stuck on the splines...i've run into same thing on different equipt before...i'm assuming tractor runs and drives...if so you mite start it in gear and drive around working hand lever back n forth...sometimes they break loose.
good luck
1755
09-19-2005 16:49:36
 Re: No Hand Clutch on my CA in reply to BCnT, 09-19-2005 09:24:38
I think the book said that you ajust the clutch when it wont disengage the ajustment takes up the slak so it will move the stuf enough to disengage
I think it is set to 20 thousanths but have not looked at this for a wile
