WD brake lower pin removal
James Herrman
09-17-2005 20:24:53
Have drilled and tapped the lower pivot pin for the brakes for 1/2 bolt to use as puller with no success. Is there any other method to remove the pin outside of using a torch??? The center of the pin is SOFT, but the outer surface is very hard and can not even touch it with a file or a saw. Any suggestions would be appreciated. Thanks is advance. JIM in ILL.
Texas Denny
09-18-2005 13:39:18
 Re: WD brake lower pin removal in reply to James Herrman, 09-17-2005 20:24:53
I got mine out on my D-17 (Same on WD and WD-45) by partially removing the entire rear axel. I loosed the bolts so that it could move out about 1/4". The movement of the axel loosened the pin. I recommend removing the wheel and fendor and getting a hoist setup from above to support the axel. You'll also need to support the rear end.
Haven't as yet had to use welding or a torch. I spend about 16 hours without success on the right pin. Had each out in about 15 minutes by loosening the axel.
JMS/MN is correct though. I've used that method on broken studs with excellent success. You need to have some skill as a welder.
JMS/MN
09-18-2005 19:47:26
 Re: WD brake lower pin removal in reply to Texas Denny, 09-18-2005 13:39:18
Thanks- I'm also a firm believer in using candle wax on stubborn heated parts. Gets in small places, threads, etc. to loosen them.
JMS/MN
09-18-2005 12:43:00
Get a 1/4 by 2 by 10 inch steel, drill a hole in one end to match the pin. Weld it to the pin. Heat of welding helps to loosen it, and you have a handle to whang one and turn. When it turns, it'll come out.
James Herrman
09-18-2005 21:55:24
 Re: WD brake lower pin removal in reply to JMS/MN, 09-18-2005 12:43:00
Thanks to all who replied to my question. I now have a new approach to apply. Thanks once again. JIM
