D-10 hydraulic pump
Joez
09-17-2005 17:32:01
I am trying to locate a hydraulic pump for an Allis-Chalmers D-10
RMD
09-19-2005 10:58:08
 Re: D-10 hydraulic pump in reply to Joez, 09-17-2005 17:32:01
You need to be more specific. There were at least three different hydraulic pumps used on the D-10. Early D-10 had the CA/WD style pump that worked off cams on the PTO shaft (hydraulics stop when engine clutch depressed) or an engine mounted pump (always live). The engine mounted pump was also used as a power steering pump on industrial models and the few ag models with power steering. After mid-1961 most D-10 had a gear type pump at the rear of the tractor that was driven by a quill shaft through the engine clutch to give independent hydraulics.
