37' WC Carb baseline settings?
WCchalmers Todd
09-17-2005 14:00:27
Still working on my WC (got it timed OK...I think). Does anyone have any baseline settings for a Zenith carb on the the 37' WC? Something like "turn the screw all the way in then turn it out 3 complete turns...."
Also I see two screws which one is which? There is one on the bottom side and one at the neck of the throttle plate.
Thanks!
old
09-17-2005 14:27:42
 Re: 37' WC Carb baseline settings? in reply to WCchalmers Todd in IL, 09-17-2005 14:00:27
Bottom is main jet and the top idle. Idle should be about 3/4 turn out from bottom and main jet about 1-1/2. Then you need to fine turn it for your engine. You want lowest RPM at idle and the Most power you can get when wide out. Takes a little playing with it to get it just right.
