info needed
BryanP
09-16-2005 15:05:36
i just purchased a 1940 AC "B" from my father in laws estate. i would like to do some restoration on it. any info anyone would share with me would be wonderful. i have some tractor experance, but not alot.
thanks Bryan
Rod (NH)
09-16-2005 19:35:53
 Re: info needed in reply to BryanP, 09-16-2005 15:05:36
Hi Bryan,
Congratulations on getting a B. The term "restoration" means different things to different people. For example, I'm not a purist when it comes to doing work on my 1942B. It's not important to me to make it "exactly like it came from the factory". Mine's a working B. I tend to make modifications to it whenever I think it is in my own best interest. In any event, you might wish to browse my web page which is, more or less, about my own B.
I think that one of the first things on your priority list should be to obtain three manuals: Operators, Parts and Service. As Steve says, you can get those from this site. You may also hear reference to an I&T shop manual. That's nice to have also but it's really no substitute for the three above which are basically reprints of actual AC-B publications.
Best that you define for yourself what you want to wind up with in the end and just jump in and start. That way, you can ask more specific questions as they arise. You are apt to get better responses if your questions are fairly specific. Lots of Bs out there. Parts are relatively easy to obtain. They were a very popular model, particularly during the '40s. A great way for the subsistence farmer to economically transition from the horse to mechanical power. That's what my Dad did and where my B came from.
third party image Rod
steve(ill)
09-16-2005 18:44:21
the B started life in 1937. in 1938 they used a BE model motor of 116 inch. by 1942 they had standardized on the CE motor, same as the model C at 125 inch. Tractor had about 18-20 HP depending on governed speed. Weight is about 2000 pounds. original was 6 volt systme, positive ground. you may have a starter and hydrualic pump, both were optional. pump is part of the hydraulic valve at the right rear corner of tractoron the POT housing.--- tractor serial number is by the trans shift lever. motor serial number in stamped on a flat boss at rear edge of the motor next to fly wheel housing bolts.---motor was magnito ignition.--- motor holds 5 quarts of oil, original 30 wt. trans-pto-bevel gear all share the same oil, 8 quarts of 20 wt motor oil, or new spec is universal hydrauilci fluid.--- if you have specific questions, ask here. if you want to get a service manual, look at the left of this page top left column. if you want to see photos, look at left collumn under "gallaries". you can buy restoration books on e-bay, or others, or just jump in and start. plenty of help here and other ALLIS site.
