WD Brake drums removal
Guyzoo
09-16-2005 09:52:22
Hi, I would like to know how to remove the brake drums on my WD so I can put new ones. I already removed the final drive housings but the only problem are the brake drums. I don't have any puller or anything to remove them without damaging the shaft.
THANKS for any suggestion
John Rogers
09-16-2005 17:53:19
 Re: WD Brake drums removal in reply to Guyzoo, 09-16-2005 09:52:22
Hi, It has been my experience that the easiest way to remove the drums is to break the outside off and then split the hub directly over the keyway with a chisel. If you need to save the drums it takes a really good puller to remove them. Good Luck, John
Mr Norm
10-17-2005 15:25:52
 Re: WD Brake drums removal in reply to John Rogers, 09-16-2005 17:53:19
For the first time, trying to replace shoes and drums on WD 45. Removed bolts/nuts from final drive housing,would only slide out approx.1/4". Next removed bolts/nuts from axle housing to diff. housing, still only 1/4. Prying did not help. Do brake shoes have to be disconected and/or removed first?
