WD45 turns out to be WD
JohnnyMo
09-15-2005 23:58:39
I just bought what I thought was a WD45 . It turns out that it is a WD , it gets worse the engine has been replaced with a 4 cyl the mec can't ID can any one give me an idea what type of engine was or is a popular replacement for a WD ? Thanks John
johnnymo
09-16-2005 10:00:29
 Re: WD45 turns out to be WD in reply to JohnnyMo , 09-15-2005 23:58:39
Thanks for the info guys ! I will try and pull some numbers off the engine when it comes back from the shop . It is in for Hydralic repair . I failed to mention that the engine in the tractor now runs good
no smoke and starts right up . I will only be using it with a bush hog and a blade to push around the snow . I am hoping it will last . Johnnymo
Jerry Coulter
09-16-2005 07:52:15
Is it for sure an AC engine? I once found a LeRoi engine off a Gehl forage harvester that bolted right into my WC. It's HP was right up there with the D17 and cranked my feed mill really good until it broke the PTO drive gear in the tranny.
John (MO)
09-16-2005 05:41:30
If it makes you feel any better, I'm sure you aren't the first person to get stung with a WD/WD45 look alike.
People ought to do just a little homework and they'd find that a WD engine has a big removable plate on the block while a WD45 does not. Most WD's have a straight stick shifter while WD45's have a curved shifter. And of course the WD45 have higher serial numbers than the WD's.
As to what engine you have, check the number on the rear of the engine near the torque tube on the foot clutch side. That should give us something more to go on. I could be a combine engine, a WC engine, or a AC replacement block if it's not a WD or WD45 block. Buy the way it's not uncommon for the blocks to have WD45 internal parts in them by now, so you may have what is close to WD45 hp from you tractor even if it did start life as a straight WD.
