WC
Brian Eckart
09-15-2005 09:13:26
Where is top dead center on a 1937 Allis Chalmers.
gene (missouri)
09-15-2005 18:02:32
 Re: WC in reply to Brian Eckart, 09-15-2005 09:13:26
If you are looking for the TDC mark on the WC, there probably isn't one. WCs usually had only a F (fire) mark.
The mark is located on the back side of the flywheel. You need to get under the (tractor) bellhousing and remove the inspection plate.
See "AC WC Timing ---", a few posts earlier. If you use my instructions you can locate the F mark. You need to use the other individuals instructions to locate which turn of the crankshaft is the compression stroke. TDC will be 30 degrees past the F mark.
Gene
old
09-15-2005 09:29:40
Do you mean the mark for it or what?? Don't understand the question.
Brian Eckart
09-15-2005 17:23:07
 Re: WC in reply to old, 09-15-2005 09:29:40
Yeah where is the mark located. And what do I line it up with. Thank You
