1948 C Front Wheel Bearings
mfmtb01
09-13-2005 20:33:27
While servicing my front wheel bearings on my Grandfather's original 1948 C I found the inner bearings a bit of a problem. It appears the inner bearings are stuck to the spindle. Is this a normal condition? Do you have to pull them with a puller or what? The cage actually came off and the rollers fell out. The inner race is still on the spindle. Also, the seal appears to be a piece of felt or something with a thin washer on each side. Can this seal still be purchased? Any help will be appreciated. Thanks.
Stan(PA)
09-14-2005 07:18:19
 Re: 1948 C Front Wheel Bearings in reply to mfmtb01, 09-13-2005 20:33:27
Yes, the races are a pressed fit, and you gotta pull them. This site offers a kit for $34.50 (each side), that contains both bearings, and the seal. The bearings are chinese (I got them for my B), and you could probably get Timkin bearings cheaper from a bearing supply house. You might be able to get the seal from the same place, or a dealer.
