WD PTO SHAFT COVER
Jim Snow SE Kan
09-12-2005 19:31:16
Friend of mine has a WD he has cracked the PTO shaft cover on and is in need of another anyone near SE Kansas have one thanks. Jim
wdtom
09-13-2005 18:15:21
 Re: WD PTO SHAFT COVER in reply to Jim Snow SE Kansas, 09-12-2005 19:31:16
What do you mean by cover? the step on the back of thetractor, or the bearing housing?
Jim Snow SE Kansas
09-13-2005 19:06:45
 Re: WD PTO SHAFT COVER in reply to wdtom, 09-13-2005 18:15:21
Talking about the cover over the shaft coming from the Clutch back to the PTO. Thanks SNOW.
Butch(OH)
09-14-2005 11:35:53
 Re: WD PTO SHAFT COVER in reply to Jim Snow SE Kansas, 09-13-2005 19:06:45
I had not a clue what you refered to as "shaft cover" in your first post and even more confused by this explanation. The shaft coming from the clutch to the PTO?? The PTO gear box hangs below the transmission case and has a stub sticking out that drives the PTO shaft with a special 7/16 shouldered bolt. At the rear of the PTO shaft is a carrier bearing, that is all there is to it, can you explain differently? Since you are in SE KS drive on down to Chelsea OK to Bob Hough's place. He probably has whatever it is you need.
Ray C. of KS
09-14-2005 03:39:54
I don't remember there being one on my WD Jim, but I will look
