Final drive lubrication on B
farmerwannabe
09-12-2005 11:46:17
How do I check the final drives oil level? Also, where do I fill them up at? I was told on here they each take 1.5 pints of 20W. Where do I drain them to change the oil that is in there? Thanks.
Same question applies to the transmission. There"s a square bolt that says next to it "oil level" or something similar. Is this where I fill it? Also, is the drain plug a hex bolt right on the bottom of the transmission? Thanks again.
steve(ill)
09-12-2005 18:29:25
 Re: Final drive lubrication on B in reply to farmerwannabe, 09-12-2005 11:46:17
the final drives are inside the rear wheel areas. you must take out a dozen little 5/16 bolts and pull the sheet metal pan off. clean out all the crud and the old cork gasket. make new gaskets from material you get at Auto Zone. i prefer the paper material, not the cork. put a quart of 80-90 gear lube in the 3/8 pipe plug hole in each pan after reassembly.--- the transmission holds 8 quarts of oil. there are 3 different pipe plugs on teh bottom under the transmission, differential, and pto housing. draoin all 3. fill at the 1 inch plug by your left foom. 20wt was the 65 year old oil. it is o.k., but new spec is universal hydraulic transmission fluid. i had 1 old C years back that i used 10w30 in the motor, and also in the transmission. works o.k., but the pump may have a little airation with using motor oil.--- make sure you use a FRAM 159C motor oil filter or similar, do not use the WIX or other paper type filter, must be the stuffed cotton design. look close at it.
Jerry Coulter
09-12-2005 17:47:15
That square top plug on the side of the tranny is where you fill with 20W non-detergent oil. You should find a plug on the inner side of each final drive pan, fill it till it runs out with gear oil, not motor oil. My B book says 140 in summer and 90 in winter. I don't know how anyone could change it without dropping the pan.
JMS/MN
09-12-2005 12:13:16
All of your answers are in the operator manual, plus a whole lot more.
