PTO leaking around seal
jbm1968
09-12-2005 07:44:27
My PTO is leaking oil from around the shaft. To remove it I have taken out the shear bolt and am trying to seperate the 2 pieces if shaft. The shaft is free( it spins after the bolt is out, I can push it in slightly but can't pull it apart. I think there is probably a grove worn and I need to just pull harder any other ideas?
JimAC
09-14-2005 14:09:38
 Re: PTO leaking around seal in reply to jbm1968, 09-12-2005 07:44:27
My main man jbm1968 forgot to say how we got the sumbytch off of there. Here goes:
1. Locked the PTO in gear.
2. Unbolted the bearing cage at the rear of the pto shaft (Probably wouldn't have to do this, but we wanted to make sure it didn't hang on that).
3. Rigged a slide hammer on the end of the PTO shaft by puting a bolt through the hole used for hooking up the implement PTO.
4. Hit with a slide hammer while twisting the PTO shaft with a BF pipewrench. This moved it out about a 1/16 inch.
5. Unlocked the PTO Shaft.
6. Heated the PTO shaft with a acyteleyne torch for a minute, then hit with the slide hammer and a pry bar at the stuck end. Came off within a minute with this technique.
7. ****TO ensure that the metallic content of the PTO shaft is not compromised MAKE SURE to pour a half can of Natural Light on the heated shaft, Bud Lite can probably be used in a pinch, but the service manual calls for Natty Light.
8. Ground down the high spots on the "inner shaft" coming out of the pto unit. The long outer PTO shaft now fits over the inner shaft nicely.
9. Talk about putting a wheelie bar on the tractor but then get tired and go to bed.
Leon in Mn.
09-13-2005 18:55:04
You need to remove the 2 bolts on the pto rear bearing support under the pto shield and slide the whole pto shaft towards the rear. I had this problem a few weeks ago and thought I could just slide it rearwards after I removed the shear pin, but it would not go to the rear until I did this. Apparently the rear bearing keeps it from moving.
Leon in Mn.
jbm1968
09-13-2005 19:59:31
 Re: PTO leaking around seal in reply to Leon in Mn., 09-13-2005 18:55:04
thanks or the help got it off just took a lot of trying and tugging. Now I hope it is only the seal
jbm1968
09-12-2005 23:26:27
Jim is my brother just messing around with me. but the pulling with a comealone is what we tried, didn't work yet
jbm1968
09-12-2005 08:33:39
I forgot to say it was a WD. I saw in the Archives that the shaft probably has the groove worn into it as I suspect. any ideas for getting it off are appreciated
JimAC
09-12-2005 11:20:43
 Re: PTO leaking around seal in reply to jbm1968, 09-12-2005 08:33:39
Well, have you taken a look at the phensver valve? Seems like I had that problem years ago on my WD45. (Make sure you don't run that tractor with no hydro oil in it, she'll burn up that pump right quick.) Once I got them ball bearings fixed up and a case of Penziol, no I think it was Quaker state, then it worked fine. Maybe you should take a come-along, put it on the end of the PTO shaft (there's a hole in the end of the PTO shaft - shove a screwdriver or somethin' in there to hold it) and then hook that to something. Get some tension on it, then take a torch and heat the sumbytch up where it's stuck. See what that does. Maybe have a fire extenguisher near by. Make sure your old man has fixed the glass bowl gasoline filter thingy before turning on that torch. One time I saw a guy burn off his eyebrows messing with Gasoline and fire!
