Bull Dozer 1955 ??
Philip-2
09-12-2005 05:58:34
I have an 1955? dozer with a clutch problem.
Model = HD5B 5151
Engin s/n = 2A2871
I needed the clutch adjusted and had one of the older mechanics look at it. Found out he wasn't as good as he said he was.
problem: there is two slotted screws and one bolt holding on the outside retainer cover to the adjusting ring where you would pry the teeth to adjust the clutch.
The slotted screws were losed by mistake and now we can't tighten them. In the manual it says "do not losen the slotted screws" but I guess he wasn't reading it right.
Now we have the two slotted screws and the single bolt lose and still did not adjust the clutch and can't tighten them up.
Question: What are the "slotted screws for"? Is there a way to tighten them without removing the adjusting plate?
What is the screws/bolts needed to adj. the clutch
properly?
Any help would be apprieciated here in CT.
hector gemme
09-12-2005 10:28:55
 Re: Bull Dozer 1955 ?? in reply to Philip-2, 09-12-2005 05:58:34
HI The two screw loose are oke like that they are helper you only just adjusted your cluch and luck the 9/16 ead bolt and I have some use hd5 parts.HECTOR
