Allis B hydraulic pump
Jeff Alexander
09-10-2005 19:19:09
My hydraulics work, but the cylinder shudders on the way up. Maybe one of the two cylinders in the pump is stuck? Wanted some ideas before I took the pump off of the tractor. Thanks!!
steve(ill)
09-10-2005 20:22:32
 Re: Allis B hydraulic pump in reply to Jeff Alexander, 09-10-2005 19:19:09
also happens when there is water in the oil, or you are using too thick of oil. should be trans-hydraulic oil, hytrans, etc.20 wt motor oil also works, but not as many addatives for antifoaming
