Oil Pick up Strainer on a D12
Vinnie
09-10-2005 13:09:36
The pickup tube connects to the strainer tube as a slip fit held in place by a cotter pin. This is a loose fit for a suction line in my opinion. The manual shows no o-ring or seal at the joint. Does anyone know if there is supposed to be a seal/gasket/o-ring at this connection? It looks like the oil pump would have a hard time keeping suction at the screen with this loose connection. My problem is that the oil pressure goes to zero after it warms up, and engine is running too hot. I have eliminated the cooling system by replacing everything but the block.
Any help is appreciated.
-Vinnie
chalmersbob
09-10-2005 19:51:25
 Re: Oil Pick up Strainer on a D12 in reply to Vinnie, 09-10-2005 13:09:36
that connection is in the oil so it can't suck air. BOB
boman11
09-30-2005 12:46:51
 Re: Oil Pick up Strainer on a D12 in reply to chalmersbob, 09-10-2005 19:51:25
Need an oil pickup screen for '57 D-14 gas. Any ideas? anyone ever make one? If so, details?
