Need AC D-21 help
Doug S in Ne
09-10-2005 09:22:28
hey all. i recently purchased a d21 and have a few questions. how do you check the transmission oil with the di[stick. it has a shaded area at the bottom and two lines above it. i know it is low and the dash light is on but which line is the full line? also how do you lower the three point? it has three levers: left and center remote hydraulics and right will raise three point when running but wont lower unless tractor is shut off. my dad owned one and said it it was a combintaon you had to do or sumthing.thanks for the help
Joe(TX)
09-12-2005 05:30:33
 Re: Need AC D-21 help in reply to Doug S in Ne, 09-10-2005 09:22:28
Is the problem only without implements attached? If without, it takes a little weight to make it go down. Are the position and draft levers on fully down?
Jr64
09-10-2005 20:28:00
My 190 has a simular dipstick. The bottom mark is for cold level and the upper mark is the hot level. Your three point problem isn't unusual. Unless the hydraulic oil is warm, the three point will not drop without weight on it, or shutting the tractor off. I hope the 21 is a good tractor for you. It's an awesome machine.
Doug S in Ne
09-10-2005 20:37:23
 Re: Need AC D-21 help in reply to Jr64, 09-10-2005 20:28:00
yeah its a great tractor especially with the turbo. plenty of power. replaced two hydraulic hoses and has a hairline crack in the center exhaust manifold. other tahn that it is in great shape with a cab. thanks for the help
